975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 07:08 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spoke thread tool??
Author Topic: spoke thread tool??  (Read 1158 times)
Offline dwain dibbly
spoke thread tool??
« on: January 24, 2008, 07:55 PM »
is there a tool available to cut the threads onto spokes?
ive just laced a set of 24" ukai's but the spokes havent tightened
enough on the rear wheel? i just thought adding a little more threads
would solve the problem  :)
Re: spoke thread tool??
« Reply #2 on: January 24, 2008, 08:18 PM »
I was going to say, make sure the spokes dont end up being too long. There is usually enough thread for a spoke nipple so cutting more would mean you'd need to cut it down.
Anyway, that tool will take care of that too. But it MIGHT cost less to get a new set of shorter spokes
Offline Moose
« Reply #3 on: January 24, 2008, 08:27 PM »
Quote
 :LolLolLolLol: :daumenhoch:
« Reply #4 on: January 24, 2008, 09:03 PM »
ah i thought they may have been a cheap hand tool ::)
do bike shops cut them?
« Reply #5 on: January 24, 2008, 09:11 PM »
Offline Moose
« Reply #6 on: January 24, 2008, 09:13 PM »
« Reply #7 on: January 24, 2008, 09:18 PM »
yes    :LolLolLolLol:
na its just i have used tem before and so so helpfull
so i will always prop a company thats handy   :)
Offline Moose
« Reply #8 on: January 24, 2008, 09:26 PM »
yes    :LolLolLolLol:
 :daumenhoch:  Just pulling your leg  :LolLolLolLol:
« Reply #9 on: January 24, 2008, 09:27 PM »
not to hard it might fall of   ;)
« Reply #11 on: January 24, 2008, 09:35 PM »
i have one of those ,its a bit wn and find some of the threads arvery shallow
as its so old i would be unsure you could buy new cutting heads
80sdave
« Reply #12 on: January 24, 2008, 10:13 PM »
Dude tell me what length spokes you have i have various 24 and 26 inch spokes and the tool to cut and thread them at work, i probably have spokes the right length but not sure if they will be black or silver. Saves you buying a tool.  :daumenhoch:
« Reply #13 on: January 24, 2008, 10:20 PM »
think i need 238mm.
its strange ive used 240mm and they worked fine on the front.
but the rear seems slightly to long?? ??
80sdave
« Reply #14 on: January 25, 2008, 09:16 AM »
Maybe the hub flange is slightly bigger, ill go measure me spokes back shortly.
80sdave
« Reply #15 on: January 25, 2008, 09:24 AM »
right sizes list up to 238mm then start from 252mm i can get you 100 with nipples black or silver for £12.50 any size i could cut and thread them for you but its not a quick job im afraid but i would like to be 100% sure of the size you have otherwise im waisting both our time, let me know what you want to do cheers.
