975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 08:38 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  painting a frame help needed
Author Topic: painting a frame help needed  (Read 883 times)
« on: March 19, 2006, 10:34 AM »
i usually stove enamel all my frames or re chrome but i have a cheep frame
that i am not spending squat on as it isnt worth nowt,i keyed it up then 2 coats of primer
at the mo 2 coats aerosol paint ,how many coats should i put on and what about laquer
i no it will scratch of easy but its not getting ridden .so coats how many and laquer how many
plus drying time
Offline sawzall
Re: painting a frame help needed
« Reply #1 on: March 19, 2006, 11:25 AM »
if youre using aerosole primer i would suggest at least 4 to 5 coats as its not that thick, then give a guide coat of black or a darker colour than the primer this will show you where you have been when wet flatting,the best way to wet flat is to use a water spray rather than a bucket as you can transfer grit dirt etc from bucket,wet flat with 1000 once all traces of guide coat have gone ,dry frame thoroughly then wipe down with panel prep degreaser if you have it, if not make sure its clean & dust free. if you use a solid colour you shouldnt need a lacquer but you will if you are doing clear over base colour, it should take about 3 coats to cover but this depends on your colour choice if you use lacquer 3 coats should do it  :daumenhoch:
« Reply #2 on: March 19, 2006, 11:37 AM »
put the frame somewhere warm to get it nice n hard
bear in mind that rattle can paint takes a week to harden
« Reply #3 on: March 19, 2006, 11:40 AM »
cheers guys its now in the house for a week then happy days when my misses gets home
i will tell her its cented candles ive been burning
« Reply #4 on: March 19, 2006, 11:42 AM »
the airing cupboard is a good place
or build a cardboard box around a radiator and put it there
heat is the key!
« Reply #5 on: March 19, 2006, 11:44 AM »
good old rattle cans the lady down town makes them up for you while you wait
take down a sample colour and she matches it spot on only 6.50 a big can
Offline jT Racing
  • i like bikes. :/
« Reply #6 on: March 19, 2006, 12:00 PM »
i tend to go over it afterwards with the wifes hairdryer. bake the stuff on.
ding dong
« Reply #7 on: March 19, 2006, 03:57 PM »
i use a paint stripper gun to heat my frames up and keep it going whilst spraying the frame
ive done a couple of frames in about 20 mins and built them up to
with no probs
