976203 Posts in 138988 Topics by 6419 Members - Latest Member: BMXBoyBrookie March 22, 2026, 11:29 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cone nut help needed - can you still buy Kink fat nuts or similar?
Author Topic: Cone nut help needed - can you still buy Kink fat nuts or similar?  (Read 4109 times)
mamadirt
I'm running a bog standard generic rear 10mm rear wheel in 14mm slots with axle adaptors but I need larger cone nuts as the standard ones are barely supported in the frame.  I know Kink used to do 'fat nuts' but I can't find them anywhere.  Spotted these - http://www.customriders.com/prodshow.asp?prodid=1624&cat=2&parent=1001&sid=3 but the mention of freecoasters is making me doubt whether they'd fit . . . I'm guessing my threads are more likely 26 tpi.
Offline Gary72
mamadirt
Re: Cone nut help needed - can you still buy Kink fat nuts or similar?
« Reply #2 on: November 23, 2009, 01:52 PM »
Cheers, they look like they'll do the job and at that price it's not too much of a problem if the thread is the wrong size.  :daumenhoch:
Offline SteveG
« Reply #3 on: November 23, 2009, 02:39 PM »
I'm after something similar as I need to fit an adaptor. Billys do an adaptor that replaces the cone nut and there are also some Diamondback ones on ebay.
mamadirt
« Reply #4 on: November 23, 2009, 05:46 PM »
Cheers!  Spotted the 4Jeri ones on the Billys site.  Ebay ones look similar though and are cheaper so reckon I'll go for those.
Offline SteveG
« Reply #5 on: November 24, 2009, 09:01 AM »
The threaded ones seem to all be 3/8", which mioght not suit what you want.
I have tried a few things and bought some chain tensioners which have a heavy duty washer on them. If you have enough space you can fit them on the inside of the dropouts and then use the adaptors as before on the outside.
