975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 10:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stuck seatpost
Author Topic: stuck seatpost  (Read 493 times)
oldsnow
stuck seatpost
« on: November 09, 2009, 09:00 PM »
hi all virgin to the forum so excuse any protocol issues. ive just got myself a chrome haro master 87 with a stuck seatpost (steel on steel) anyone else had this prob ? and  how do i get it unstuck ?
ozone
Re: stuck seatpost
« Reply #1 on: November 09, 2009, 10:44 PM »
This trick definitely works and doesn't involve heat or special tools...
Spray a bit of release oil onto the post, hopefully it will work it's way down there (best to leave for a while).  Lie the frame on the floor, then get an old handlebar stem and clamp it to the seatpost (tight enough so it doesn't slip)  then get hold of some tubing or a set of forks and slide the tube over the stems shaft.  Once everything is tight you should be able to start working the the tube/forks back and forth until the post starts to move.  You'll probably have to stand on the frame.  Longer tubing = more leverage :D.  Once it starts to move, just keep working it back and forth or keep turning in one direction and it will work it's way out.
Give it a go - it always worked for me.  If all else fails, there's heat...
oldsnow
Re: stuck seatpost
« Reply #2 on: November 09, 2009, 10:58 PM »
cheers ozone i'll give it a go & hollaback !
