975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 01:08 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  straigh stay ripper
Author Topic: straigh stay ripper  (Read 591 times)
Offline HUTCHMAN
straigh stay ripper
« on: November 04, 2009, 06:09 PM »
Can anyone do(or has got) a side on pic(real close up) of the very rear end of a straight stay/curved stay ripper.i need to see the datail of the two notches.the r/h dropout has been ground away by a badly fitted wheel,but the welder took it upon himself to put some weld over the notches on the l/h dropout.now i've got no reference point to refinish the other side.also could the distance between the notches be measured,i should imagine it's 10mm.any help appreciated.
Dave.
Offline HUTCHMAN
Re: straigh stay ripper
« Reply #1 on: November 04, 2009, 06:52 PM »
thanks bubby,your a star.  :daumenhoch:
moley
« Reply #2 on: November 04, 2009, 07:03 PM »
The Notches are 5mm wide and the gap between the top notch and the bottom notch is around 10mm (which amazingly, is the size of an axle!!!)  :D
I used a plastic crappy ruler so the measurements are approx!!
Offline HUTCHMAN
« Reply #3 on: November 04, 2009, 07:25 PM »
cheers Moley,it all helps.
