975755
TattooedYorkie
September 22, 2024, 02:48 AM
fork dropout distance
Topic: fork dropout distance (Read 553 times)
bmxbert
November 04, 2009, 01:26 AM »
why wont any of my mid school wheels fit in my trick stars forks. do i need to take lock nuts off the cones? if so that fooking sucks
the f&f are minty mint i dont get it
bmxbert
Re: fork dropout distance
November 05, 2009, 11:04 PM »
help please
fouronethreeoh!
November 06, 2009, 08:25 AM »
My 84 GT forks measure 97mm between dropouts, my early 90s Ditchforks measure 99mm, and my 2000s Pitchforks measure 101mm. I would have thought that Peregrine(Suzue) hubs would fit straight in.
ozone
November 06, 2009, 11:24 AM »
Quote from: bmxbert on November 05, 2009, 11:04 PM
help please
I have had this problem before. You need cones which are shoter than the ones on your mid school wheels - the lock nuts on your cones are probably quite thick and there might be washers in between so they need to be taken out. The best solution is to buy an old school axle that has short cones with a thin flatted end and thin lock nut. A skyway axle kit would probably work but any old school axle should do it.
Maybe someone has the cones and locknuts in their toolbox - i haven't unfortunately
