975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 12:03 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spoke length sticky?
Author Topic: spoke length sticky?  (Read 576 times)
Offline rooski
  • Mons Veneris
« on: October 27, 2009, 08:38 PM »
i have noticed that there are many radsters trying to find correct spoke lengths for builds.
obviously most combos have been worked out successfully.
would a sticky, or thread be possible ???
would this be fraught with disaster? ie some worked out incorrectly,confusion between 3 cross,4 cross etc?
Discuss.
nosepickben
Re: spoke length sticky?
« Reply #1 on: October 27, 2009, 10:50 PM »
Measure your hub flange width, the diameter of the centre of the spoke holes (down to a millimetre or so), your rim internal diameter, lacing pattern (usually 3-cross works and looks better on 36's, 4-cross for 48's) and use the "dt swiss" spoke length calculator on their website. Round upwards by a mil or so on the length quoted and you won't go far wrong. Has worked for me everytime.
http://www.dtswiss.com/SpokesCalc/Welcome.aspx?language=en
Hit the "anonymous usage" and good luck.
Offline rooski
  • Mons Veneris
« Reply #2 on: October 28, 2009, 05:17 PM »
i used SPOCALC, which was easy to use.
Araya Aero, suzue small flange 3 cross =184mm
                                                  4 cross=190mm
built up no probs :daumenhoch:
