975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 11:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tuf neck stems
Author Topic: tuf neck stems  (Read 732 times)
moanjam
tuf neck stems
« on: October 09, 2009, 10:39 PM »
after removing the wedge and wedge bolt can you remove the ally body from the stem ??
Offline kuwahero
    • Western Titans
Re: tuf neck stems
« Reply #1 on: October 09, 2009, 10:43 PM »
yes. I had to gently heat mine to expand the hole slightly and then press it out.
no I need to put it back together.  :LolLolLolLol:
moanjam
Re: tuf neck stems
« Reply #2 on: October 09, 2009, 10:47 PM »
cheers marc  :daumenhoch: .. is there a technique mate
Offline kuwahero
    • Western Titans
Re: tuf neck stems
« Reply #3 on: October 09, 2009, 10:52 PM »
gently heat the body with blow torch or stick in oven with yer dinner. screw the big bolt about half way in and keep taping the top with a rubber mallet and it will eventually come out.
moanjam
Re: tuf neck stems
« Reply #4 on: October 09, 2009, 10:56 PM »
cheers dude
Re: tuf neck stems
« Reply #5 on: October 10, 2009, 07:18 AM »
well i never...    :shocked:
gona try that... :)
(((sonic)))
Re: tuf neck stems
« Reply #6 on: October 10, 2009, 07:30 AM »
Heat works wonders, (although i have never thought about the oven, good idea though  :daumenhoch: ) both these where completely pulled apart for a once over........
B
Re: tuf neck stems
« Reply #7 on: October 10, 2009, 07:34 AM »
think that stem needs a polish ...lmfao
