can you just push the cable inner throu the hole and then push the cable back on after feeding the inner all the way throu
yes understood and thats what i ment,thread just the inner throu..strangei wouldnt use a blank end and knarp as you would never get it lined up either.
I`ve got an MX99 somewhere (can`t find it now I need it!) and when you pull the lever back,there is a steel Pivot type thing inside connecting the lever to the body.The cable end just fits into this.Wish I could find my lever so I could give a more accurate description for you...
