975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 12:01 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  plenty of staying power...
Author Topic: plenty of staying power...  (Read 1151 times)
Offline Peanut
« on: September 23, 2009, 09:45 AM »
..naff all stopping power
Just set up my winter ride and the u990's aren't doing anything, plenty of play at the lever yet nothing happens at the brake end. It could be the levers, they're odyssey 2000s but I'm  sure they used to work, or maybe the cable run is too long/tight. I'm running the front through a potts mod, does that make a difference?
Re: plenty of staying power...
« Reply #1 on: September 23, 2009, 10:23 AM »
and make sure you spray loads of WD40 down the outer cable as the inner will bind at the turn on the forks......WD40 makes it nice and slippy  :daumenhoch:
Offline Peanut
« Reply #2 on: September 23, 2009, 10:24 PM »
yay! thanks chaps, front isworking a treat now, crappy rear tektro is a pile of sh1te tho, at least its now rideable enough for work tomorrow
