975882 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 01:06 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Hubs help needed - 16t freewheel to 13t cog
Author Topic: Hubs help needed - 16t freewheel to 13t cog  (Read 811 times)
Offline jimwise68
« on: March 08, 2006, 09:59 PM »
HELP!!!!
I've just acquired some new school wheels and the rear has a Bulletproof hub with a 16 tooth freewheel.
Anybody know if I can put the 13tooth cog from my Haro hub (Nyquist R2) on or willl I need to strip down both the hubs to get the relevant bits?
I hope that makes sense.
Or would it be easier just to get a longer chain!!!  :LolLolLolLol:
rom_kid_04
Re: Hubs help needed - 16t freewheel to 13t cog
« Reply #1 on: March 08, 2006, 10:04 PM »
nope you would need to use a different hub as a small freewheel 13/14t is a different size to a 16+freewheel
Offline jimwise68
« Reply #2 on: March 08, 2006, 10:18 PM »
Longer chain it is then.
feck.
That will screw my gearing up.
Thought that I might have been able to remove the inners from the haro hub to the Bulletproof hub so I can get my 13t on there.
silentpartner
« Reply #3 on: March 08, 2006, 10:26 PM »
you need to have a flip flop hub which allows you to run various sizes. one side runs 14 /15 tooth, and some 13 tooth freewheels, and the other side allows you to run 16/17/18 tooth freewheels. if you want to run a 13 you'll need that sized thread, stripping the hubs wont help, you need to change the hub. if you want to run all sizes of sprocket size get a cassete hub, were you can run as low as a 9 tooth up to 18. hope that helps.
alan  ;)
Offline jimwise68
« Reply #4 on: March 08, 2006, 10:29 PM »
Cheers Alan
that spells it out nicely.
Will have to get a longer chain for now then until I get the hub sorted.
thanks
Jim
« Reply #5 on: March 08, 2006, 10:34 PM »
longer chain and pedal like mad lol
Offline jimwise68
« Reply #6 on: March 08, 2006, 10:50 PM »
Rhys PM'd you!
