975766
TattooedYorkie
October 05, 2024, 10:20 AM
BMX General
BMX Chat
Help installing profile cranks
Topic: Help installing profile cranks (Read 526 times)
dazwest
September 12, 2009, 01:13 PM »
Afternoon all
I'm installing some shiny new profile 180's and I'm just about done but I'm still left with a gap on the axle. I've used all the spacers (5 - 2 on drive side and 3 on other side) but theres still a gap. Have I done something wrong or do I just need more spacers?
Any advice appreciated.
Daz
fugazi
Site Supporter
540 Air
Re: Help installing profile cranks
September 12, 2009, 01:36 PM »
Hi dude, what frame & bottom bracket are you putting the Profiles in?
dazwest
September 12, 2009, 01:47 PM »
Hey
Its a Dialled MX20 with profile Euro bb.
cheers
gobshite
September 12, 2009, 02:28 PM »
http://bmxmuseum.com/forums/viewtopic.php?id=30010
fugazi
Site Supporter
540 Air
September 12, 2009, 02:30 PM »
You might need another spacer or two in there then by the sounds of it
did the b/b have the wider alloy bearing cover/spacers?
gobshite
September 12, 2009, 02:33 PM »
http://www.profileracing.com/ht_crank_install.php
gobshite
September 12, 2009, 02:34 PM »
and just to repeat,
be careful with the threads
dazwest
September 12, 2009, 02:43 PM »
Nice one, thanks.
No spacers left. Can I use the spider adaptor on the non-drive side as that would act as a big spacer?
gobshite
September 12, 2009, 02:47 PM »
its not ideal but it might run ok,
if you've used all the spacers just second check that theres enough axle left to support the arms,
and get the proper spacers for it as soon as you can,
dazwest
September 12, 2009, 03:11 PM »
thx for your help chaps
moley
September 12, 2009, 05:41 PM »
Theres always the possibility that your not tightening them up enough!!
How much of the axle is showing through your crank arms?
When I tighten mine I usually have to use spare aluminium washers on the profile tool so that I can tighten it up more.
I also use a Hop up kit to space the crank out as they look nicer than the washers.
You can buy the hop up kit as part of the Bottom bracket set. 2 cups, 2 bearings, 2 bolts and the hop up kit from loads of places
Or
Just buy the 2 hop up from here. I dont think they are made by profile but they fit and do the job.
http://cgi.ebay.com/profile-BMXbike-3pcCrank19mm-CONE-WASHERS-silver-new-13_W0QQitemZ230353352772QQcmdZViewItemQQptZCycling_Parts_Accessories?hash=item35a2213844&_trksid=p3286.c0.m14
THIRSTYKIRSTY
Reply #11 on:
September 12, 2009, 05:57 PM »
could also be a mtb spindle 155 i thuink they are and a bmx should be 145
gobshite
Reply #12 on:
September 12, 2009, 06:03 PM »
theyre mid/ bmx bb size moley, wont work with profiles euro bb,
tbh i always though the euro cone spacers came with the profile euro kit
BMX General
BMX Chat
