976208 Posts in 138989 Topics by 6419 Members - Latest Member: BMXBoyBrookie March 26, 2026, 01:01 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  SUGINO CT CRANK NIGHTMARE!!!!!!!!!!!!!!!!!!!!!!!
Author Topic: SUGINO CT CRANK NIGHTMARE!!!!!!!!!!!!!!!!!!!!!!!  (Read 1691 times)
« on: September 11, 2009, 12:23 PM »
You wouldn't believe it guys but I picked up a cheap one recently that needed rechroming, and today I visited my chromers and they have seriously fooked it up  :'(
The spider I only found out today which is part of it is Alloy, the crank arms Steel. It was originally black, so they dipped it to clean off to the paint and the stripper is so strong it basically has eaten the spider  :-\ When I told him how much these cranks are worth the guy crapped himself, but suggested that they can re-fabricate the spider as a solution to the problem.
So I will need either two things....
1) An outline of the spider (on a piece of paper) with some ideas of thicknesses or...
2) Someone send me that drive side with spider attached and they can get it lazer measured and then machined
Can anyone on here help?
This will hold up my 84' Haro Master build now but there you go...  :-\
Thanks in advance...
Matt  :daumenhoch:
Offline se-bmxer
Re: SUGINO CT CRANK NIGHTMARE!!!!!!!!!!!!!!!!!!!!!!!
« Reply #1 on: September 11, 2009, 12:29 PM »
or i could get a fooked up one from shiners next week if you want and start again
« Reply #2 on: September 11, 2009, 12:35 PM »
Sounds good Jai, keep me posted  :daumenhoch:
« Reply #3 on: September 11, 2009, 12:36 PM »
Jeez thats shite.  What chromers were these, so we know not to go there?
Yep not good Glen. I must admit, for everything else these chromers have been spot on, they just failed this time to work out what was steel and what wasn't due to the crank being heavily painted. Sods law it had to happen just as I have everything to build the Master now  :-\
Offline se-bmxer
« Reply #4 on: September 11, 2009, 12:37 PM »
im back at work Tuesday  :daumenhoch:
Juju
« Reply #5 on: September 12, 2009, 04:11 PM »
If you still need help,I've cot 2 ct's sitting here waiting for a couple of rebuilds, that I wont need for a couple of weeks min.
Pm me your address if you need me posting one off to you.  I've got a DB F1 (ie with the black painted spider, and a clean virtually (but not quite) nos CT as well).
« Reply #6 on: September 12, 2009, 06:31 PM »
o dear, i reckon they did it on purpose
« Reply #7 on: September 12, 2009, 09:30 PM »
 :knuppel2: ;D
Offline HUTCHMAN
« Reply #8 on: September 12, 2009, 10:41 PM »
which spyder does it have? the redline 400 style(swedged on) or is the A5 type?
