975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 03:18 PM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  U brake plate
Author Topic: U brake plate  (Read 3380 times)
Glen
U brake plate
« on: September 03, 2009, 05:20 PM »
How well do U brake plates work on the front?  Ive never used one, alghough I have a feeling theyre pretty flexy and crap..
Offline Bigfrawg
Re: U brake plate
« Reply #1 on: September 03, 2009, 05:22 PM »
not bad , i had a fishbone one that clamped on to the fork legs aswell as bolting through the hole in the forks
Offline Bigfrawg
Re: U brake plate
« Reply #2 on: September 03, 2009, 05:33 PM »
i think someone is selling lugged forks for a £ 10 in the for sale section mate
condor96
Re: U brake plate
« Reply #3 on: September 04, 2009, 02:59 AM »
ive had good luck with 990 plates on the front. the trick to take any flex out is to make sure it has a stong bolt that you can put some tourque to and use washers on the bolt behind the plate to where the plate rest equally on the steerer tube and fork legs. that way the plate doesnt get pulled back/angled towards where its being clamped by the bolt and "teeter".
thecaptain
Re: U brake plate
« Reply #4 on: September 04, 2009, 06:32 AM »
Its also a good idea to use hose clamps just above or below (depending on the make of brake plate) the brake lugs, stops and movement side to side and eliminates any pivoting
Offline fugazi
Re: U brake plate
« Reply #5 on: September 04, 2009, 11:45 AM »
I've got a Hoffman plate made from alloy, no flex if you use a decent bolt but being alloy it's thicker so sticks the front brake out a bit more than steel, I'll dig it out if you're interested  :daumenhoch:
Offline fugazi
Re: U brake plate
« Reply #6 on: September 04, 2009, 12:08 PM »
Hopefully the bolt is still with it, I can't remember! I'll be able to get at it a bit later this afternoon.
Offline fugazi
Re: U brake plate
« Reply #7 on: September 04, 2009, 05:05 PM »
its ok mate, ive bought the complete shimano front brake setup from Steve, thanks anyway  :daumenhoch:
No worries, glad you got something sorted  :daumenhoch:
gobshite
Re: U brake plate
« Reply #8 on: September 04, 2009, 08:14 PM »
come on guys ,
calm down,
its not some fooking greek restaurant.
Offline fugazi
Re: U brake plate
« Reply #9 on: September 04, 2009, 08:30 PM »
come on guys ,
calm down,
Huh? You're right, it's not a Greek restaurant, it's a brake plate.
