975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 09:06 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rounded Stem bolt..
Author Topic: Rounded Stem bolt..  (Read 820 times)
nic968
Rounded Stem bolt..
« on: September 01, 2009, 12:18 PM »
 I've been trying to remove a stem bolt from a DK stem but it's just getting rounder and rounder....
 Any solutions? It's still on the bike and a really nice stem, so I'm trying to be carefull...
moley
Re: Rounded Stem bolt..
« Reply #1 on: September 01, 2009, 01:37 PM »
Are you using the wrong sized spanner?
If your using metric then use an imperial one!!
I have a habit of using the wrong one and although it fits and seems to work.  Once its tightened then it tends to slip and starts rounding the edges off.
I had rounded bolt (slightly) that needed removing.  So I filed a couple of the spurs off and tapped (twatted) a socket (correct size) onto it and then I managed to get it off.   I then twatted the bolt off the socket using a metal rod that fit into the square drive hole!!
The socket came out of it without any damage but thats probably down to luck!!
I wouldn't use an adjustable spanner as they are quite slack and hard to get fully tightened and stay tightened while turning!!
Not much use am I!! :-\
« Reply #2 on: September 01, 2009, 02:20 PM »
I use these spanners-Socket set
http://www.metrinch-tools.com/website/introductie.php?language=gb
They fit both metric & imperial & they grab the flats of the nut so no rounding off  :coolsmiley:
« Reply #3 on: September 01, 2009, 03:10 PM »
If the holes go al the way through try drilling it out from the back. The thread may catch and unscrew itself, it's how we do it at work.
nic968
« Reply #4 on: September 01, 2009, 03:24 PM »
 Those Metrinch tools look excellent..I'll investigate..
 Thanks for all replies fellas.
