975755
TattooedYorkie
September 21, 2024, 06:21 PM
haro Axle spacers
Topic: haro Axle spacers (Read 898 times)
spleen1970
haro Axle spacers
August 29, 2009, 08:49 PM »
93 haro master forks the ones with fork stander screw thread at the bottom
now then I have gone to fit a skyway Front wheel with a 10mm axle but it dose'nt fit the drop out is to big .I have been advise I need a top hat spacer to fit the wheel .
Is this correct ?
Dose anyone have any ?
Please let me know
many thanks sean
rollin72
900 Air
I was a ninja
Re: haro Axle spacers
August 29, 2009, 09:01 PM »
check out the rad shop they have some there
spleen1970
August 29, 2009, 09:14 PM »
Cheers dude il have a look
spleen1970
August 29, 2009, 09:27 PM »
Iv been told it's not 10mm to 14mm adaptor's I require they said I need a top hat spacer & that the forks are 12mm drop outs not sure if this is correct the rear wheel drop out's are 10mm the forks are tapered
Cheers sean
graeme
Curb Endo
August 29, 2009, 09:53 PM »
vert ego has em, you need the SE axle washers, they are 10mm to 12mm top hat washers.
I recently got some for my haro forks.
HEYWOOD BMX
August 29, 2009, 09:56 PM »
http://www.chainreactioncycles.com/Categories.aspx?CategoryID=179
Atomlab 12-10 conversion
Lots of forks have the same problem.The washers look like these,but I got 4 from my local bike shop for a quid.
HARODAVE
Rockwalk
the artist formerly known as DAVE3172 !!
August 29, 2009, 09:58 PM »
alans sell 10-14mm axle converters too ..i got some for my 06 sport and they`re bob on!!
haro Axle spacers
