975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 05:06 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Headset fitting problem
Author Topic: Headset fitting problem  (Read 5646 times)
Offline Robbo
« on: August 25, 2009, 07:43 PM »
Tried test fitting an Odyssey pro headset to the Zippo build and the bottom bit is struggling to fit over the raised bit on the steerer tube. I've not tried to persuade it on yet with any force but I'm wondering if this is normal or do I need another headset?
I've have thought about introducing the raised bit to my friend the dremel just to take the edge off and help with the fitment....
Any advice really wlecome. :daumenhoch:
Offline DIRTBIKER250F
  • Home sweet home
Re: Headset fitting problem
« Reply #1 on: August 25, 2009, 07:47 PM »
Tap it down with a flat head and a screw driver  :daumenhoch:
(What the fook do i type sometimes ???? , flat head and a Hammer  :daumenhoch:)
« Last Edit: August 26, 2009, 02:07 PM by DB250F »
« Reply #2 on: August 25, 2009, 07:50 PM »
twat it with a massive hammer....no, do what db says >:D
« Reply #3 on: August 25, 2009, 07:58 PM »
ya need to drop the washer in boiling water then it will fit better
or get one of ya mechanics at work to wack it on
Offline Robbo
« Reply #4 on: August 25, 2009, 08:06 PM »
Cheers for the tips gents. :)
Offline HUTCHMAN
« Reply #5 on: August 25, 2009, 08:34 PM »
if your going to go the dremmel route,i'd do the race not the forks or get it pressed on with a length of something like scaffold pole.
« Reply #6 on: August 25, 2009, 08:42 PM »
Robbo, I had the same issue with my 91 haro forks, in the end I used the pole over the stearer tube.
Just make sure you support the steerer underneath rather than having the dropoutsd take the strain
Offline Robbo
« Reply #7 on: August 25, 2009, 09:24 PM »
Where did you get the pole from?
I've used a dremel before for fitting a headset, wasnt to proud of that method but it seemed to work.... ::)
Offline stevochb
« Reply #8 on: August 25, 2009, 11:10 PM »
get a large shifter and open it so that it rests ontop of the race then tap with hammer turn the forks 90 degrees then tap again keep doing that till its on. You might have to use a bit of force though.
« Reply #9 on: August 26, 2009, 08:34 AM »
rob they are spose to be a tightish fit mate
« Reply #10 on: August 26, 2009, 08:37 AM »
i used an old hoover tube, it opened up a little at the end once i'd finished but it worked a treat  :daumenhoch:
moley
« Reply #11 on: August 26, 2009, 08:54 AM »
Did your headset come with 2 sizes of Bottom Race?
GT/FSA headsets come with 2 for different sized fork races.  I think to cover normal 1" forks and the oversize 1" forks that some firms brought out in the early - mid 90's before 1 1/8" forks aheadset came out.
It should never be loose (always tight) and if its a NOS Fork then you'll have to do some real twatting to get it on.   Its usually slightly easier (although still hard) the next time you do it.
I use a large adjustable Spanner and a big fooking hammer.  Close the spanner over the forks so that it makes contact with the top of the race and then try and smack it around the race so it goes on evenly.   If it goes on at a steep angle then its even harder to get on.
Good luck!!  :daumenhoch:
« Reply #12 on: August 26, 2009, 10:02 AM »
i tried that on mine and still wouldn't go on  >:(
Offline Robbo
« Reply #13 on: August 26, 2009, 10:47 AM »
What I did was popped it into a pot, boiled it in water for 2 or 3 mins it goes on with very little bashing when its hot.  Make sure you grease the forks well of course!
I'll give that a go, want a practise run before I get the forks powdered.
Thanks for the advice so far. :)
« Last Edit: August 27, 2009, 09:10 AM by 'Robbo' »
jon foz
« Reply #14 on: August 26, 2009, 07:09 PM »
I just used a small square edged file by hand and filed it around the fork,working around as i went,just do a little at a time as you want a tight fit
Jon
yelmarb
« Reply #15 on: August 29, 2009, 11:05 PM »
