975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 05:36 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Mounting a bike on the wall, what brackets are you using???
Author Topic: Mounting a bike on the wall, what brackets are you using???  (Read 1265 times)
martylaa
As it says above i want to put a bmx bike i've built on a wall in my office, anyone out there recommend some quality bike mountings/brackets for doing this?
Oh and please lets not have the bikes are mean to be rode stuff on here, i agree but some are'nt also if you know what i mean :daumenhoch:
telelogic
Re: Mounting a bike on the wall, what brackets are you using???
« Reply #1 on: August 19, 2009, 12:00 PM »
I've got my bikes hanging in the garage using these,
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_522909_langId_-1_categoryId_228379
I've had no problem so far, and they are cheep!
Offline priv
« Reply #2 on: August 19, 2009, 01:13 PM »
yep as above, but cut it down so the bike sits closer to the wall :daumenhoch: :daumenhoch:
mark 2
« Reply #3 on: August 19, 2009, 01:50 PM »
Where did you learn that from?   :LolLolLolLol:
The bike doesn't sit in a natural angle in those brackets, the front end dips right down depending on how extreme the angle is on your top tube. So another tip is, when you cut them you need to re-drill the hole to replace the rivet with a bolt. Cover the hanging bracket bit where you need to drill in masking tape. Place the bike on the floor and place the braket in place on the frame so it sits in the wall mount bit at the bikes correct angle. Poke a pen through the holes to mark where you need to drill. Then when you bolt it all together the bike is in its natural  position. It'll all make sense if you had it in front of you and you chop it up.
« Reply #4 on: August 19, 2009, 02:04 PM »
put bracket at height you want it, mount with one bolt to wall, hang bike on, adjust til looks right, hoy in last screw, can't go wrong :daumenhoch: get some short stretchy tie things to attach to the bracket n ya bike to pull the bottom end towards the wall
martylaa
« Reply #5 on: August 19, 2009, 03:33 PM »
where did you get those brackets from my good man?
« Reply #6 on: August 19, 2009, 03:43 PM »
i think this is where i got em from, http://www.bikecare.co.uk/acc/cyclestands.html , they are very similar to the halfords ones and were the same price when i got em but a couple of quid more now, not sure about halfords ones, but these have a soft foam over the hooks  :daumenhoch:
Offline priv
« Reply #7 on: August 19, 2009, 03:51 PM »
i haven't got mine up yet
mark 2
« Reply #8 on: August 19, 2009, 04:01 PM »
halfords do them, made by raleigh, tenner with everything you need, covered in foam too.
martylaa
« Reply #9 on: September 21, 2009, 03:57 PM »
Cheers boys the Halfords one done the trick, don't think the missus will like her new wall decoration mind, it did'nt exactly come from Laura Ashley  :LolLolLolLol:
« Last Edit: September 21, 2009, 04:05 PM by martylaa »
telelogic
« Reply #10 on: September 21, 2009, 04:02 PM »
they don't have anything That nice in Loura Ashley :daumenhoch:
martylaa
« Reply #11 on: September 21, 2009, 04:34 PM »
haha she won't agree for some strange reason  :daumenhoch:
now maybe if i painted it duck egg blue she might let me put it up in the living room  :LolLolLolLol:
telelogic
« Reply #12 on: September 21, 2009, 04:47 PM »
Get a Ripper, Job done :)
Offline priv
« Reply #13 on: September 23, 2009, 12:23 PM »
I finally got mine up{oohh err mrs ;)}
Offline SteveG
« Reply #14 on: September 23, 2009, 12:33 PM »
I've run out of space for stuff now so wall hanging seemed a good idea. Trouble is the walls upstairs in my place are't very strong so I ended up putting hooks in the joists and hung them up from them.
I can get some more junk in my computer room now !
Offline priv
« Reply #15 on: September 23, 2009, 03:10 PM »
Mines hung on pasterboards walls,i sawed about 4-5"off the bar so it sits closer to the wall and drilled an extra hole on the bracket just to be on the save side and 3 weeks later it's hasn't moved.
Offline SteveG
« Reply #16 on: September 23, 2009, 11:39 PM »
It probably would have been ok to do it like you say. I've got whats best described as plasterboard covered straw walls !
Hope we never get any mice.  ;)
neiljonarcus
« Reply #17 on: December 02, 2009, 07:12 AM »
thats a nice frame and forks  .................looks like a nice paint job too  :LolLolLolLol:
Offline priv
« Reply #18 on: December 02, 2009, 05:33 PM »
that took you long enough to reply ;) :daumenhoch:
