976212 Posts in 138990 Topics by 6418 Members - Latest Member: RickmanMan74 March 29, 2026, 05:02 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  wheel trueing and tension
Author Topic: wheel trueing and tension  (Read 1257 times)
Offline graeme
« on: August 13, 2009, 12:33 PM »
I built a pair of wheels for a rider. They seemed to come together ok.
Ive trued them the best i can, there not too bad, maybe 1mm out.
I dont seem to be able to get them any better so i was going to get our local shop to true them.
From what ive read though, you have to true them, then ride for a bit to settle everything, then true again.
So, i was going to use them for a few hours first, but what sort of tension should i have in the spokes? I guess thats a hard thing to say without some kind of 'tension machine', but can anyone give me any idea?
or, should i just get them done at the shop now?
Thanks.
Offline Bigplinky
Re: wheel trueing and tension
« Reply #1 on: August 14, 2009, 08:24 PM »
All I can suggest is go to a decent shop and feel how tight the spokes are on a set of wheels that are ready to go i.e. press together the pair of spokes that cross over between the rim and the crossing point. I normally tighten then to about 8/10th of fully tight (the nipples) if that makes any sense but depends on the size of your spoke key.
Hope that helps
Andy
Offline graeme
« Reply #2 on: August 14, 2009, 09:25 PM »
thanks.
If i get them trued at the shop before i start riding them, will they need re-trueing pretty quickly after, once they have been ridden a hour or 2?
« Reply #3 on: August 14, 2009, 10:55 PM »
machine built wheels need re trueing, decent hand built wheels do not
Offline graeme
« Reply #4 on: August 14, 2009, 10:57 PM »
cool.
May as well run em straight down the shop then :)
