975808
Robertflamn
November 26, 2024, 04:23 PM
Powder over chrome - RESULTS!!
Topic: Powder over chrome - RESULTS!! (Read 1602 times)
wildon
Flip-Whip
August 01, 2009, 01:45 PM »
OK, i picked up a chrome trickstar the other day ... thing is i already got one that i had rechromed so wanted to powder this metalic blue. however, this TS has the og chrome and its in quite good condition .. i dont really want to strip it or wreck it in anyway. If i get it powdered are they able to do it straight over the chrome and would the powder be easy to remove without damaging the chrome underneath if i wanted to in the future?!
Although, the forks have a small dent and some donut has drilled an extra hole in each of the drop outs, both of which i may get filled in (which will obviously wreck the og chrome) .. so what do i do? thoughts guys...?!!
Last Edit: August 14, 2009, 05:05 PM by wildon
neiljonarcus
Re: Powder over chrome
August 01, 2009, 02:04 PM »
well any substrate has to be keyed in some way shape or form .."da disc or scotch brite"..now if you powder over chrome and dont key it ,it will chip very easy . but in the future you can get it dipped in a solution which will stripped the powder off and leave the chrome underneath un harmed . now for filling in them holes it will have to be welded because if you use bodge "body filler " it doesn,t go up to the powder coating oven does round about 220 . and the bodge will pop and the job will be knackered but any good powder coater will not powder over bodge
hope this helps
wildon
Flip-Whip
August 01, 2009, 02:15 PM »
Yeah does thanks ... what i was thinking though is if i do get the forks repaied the og chrome will be fooked anyway so it dont really matter what i do to it .. og chrome frame and rechomed forks will just look funny.
Not too worried about the powder chipping easily as will only be a show pony ... did i read somewhere though that it's good to put a metallic colour over chrome ... does it change the finish in any way?
b45t4rd
August 01, 2009, 02:24 PM »
Had some chrome forklifter bars powdercoated, the place I use always shot blasts everything before coating.
http://www.powder-coatings.ltd.uk/motor.php
Last Edit: August 01, 2009, 02:29 PM by vestan pance
neiljonarcus
August 01, 2009, 03:02 PM »
Deano
August 02, 2009, 02:27 AM »
I had a big dent in a frame i was getting coated. So i used quick steel (epoxy?) and it held under the powder fine. Did swel a little or i never sanded it enough but its better than a hole /dent imo.
Will ruine the chrome tho id guess.
Powder over chrome where did i see that lately hmmmmmmmmm
neiljonarcus
August 02, 2009, 07:53 AM »
yeah for sure powdering over chrome will work my powder coaterhas translecent gold / blue / red if you have a look at this thread i put up a while ago the super burner is chrome with gold laquer powder over it
http://www.radbmx.co.uk/forum/index.php'topic=81287.0
wildon
Flip-Whip
August 14, 2009, 05:05 PM »
OK ... didnt get the dent and the holes in fork drop outs filled as wanted to leave the mint OG chrome untouched. The guy at the powerders said it wont be as durable as there aint no key for the powder but it wont be ridden anyway. I recon it turned out mint!
Before
After
Swivel
Berm Worm
Ah feck it, go on then...
Re: Powder over chrome - RESULTS!!
August 14, 2009, 05:06 PM »
MMMMMMMMMM yum yum, that looks lovely mate
meticulous
Berm Worm
August 14, 2009, 07:41 PM »
that does have a nice finish, and you could easily return it to chrome if you fancy a change, just dont tighten the wheel nuts up tight.... and get the headset and BB pressed in, rather than whacked in, i would personally sand the edge were the cups go in so the cups dont touch the powder, or you risk chipping the edge off, another tip, when you sand dont go 'in and out' of the tube with your sand paper, sand around the edge carefully to prevent lifting off the powder....
R.I.P O.M. Far short of the finish line...
Glynnyboy
Look Back
August 14, 2009, 08:40 PM »
Blue superchrome, lovely
neiljonarcus
Reply #11 on:
August 14, 2009, 08:59 PM »
translucent powder looks the nuts . i am
that hutch mate 100%
wildon
Flip-Whip
Reply #12 on:
August 14, 2009, 09:14 PM »
Thanks guys .. i am well chuffed with it
and thanks for the tips meticus .. will do that mate
Now with decals ....
jT Racing
BMX Overlord
i like bikes. :/
Reply #13 on:
August 16, 2009, 06:27 PM »
sweeeeeet colour
ding dong
