975755
TattooedYorkie
September 22, 2024, 06:31 AM
suntour freewheel abit stiff
Topic: suntour freewheel abit stiff (Read 631 times)
LOS1969
July 06, 2009, 06:28 PM »
is it fooked or what?
fugazi
Site Supporter
540 Air
Re: suntour freewheel abit stiff
July 06, 2009, 06:36 PM »
Take it off the hub & spray wd40 or similar through it, or soak it in petrol, see what it spins like then. If it's ok spray in some fresh lube, wipe off the excess & you're sorted
JD_76
July 07, 2009, 01:47 PM »
I had a new one like that, it had surface rust in the bearings and sounded all grindy. I just sprayed it with GT85 and ran it, sounds sweet as a nut now.
J.
thecrooch
July 07, 2009, 02:55 PM »
you flush whatever grease was in there out like that... its a short term fix but basically yeah its on the way out....
ruff n tuff
Rockwalk
July 07, 2009, 02:59 PM »
depends if you fancy opening it up and re-greasing it - a real faff job and be careful not to lose the ball bearings....
HEYWOOD BMX
July 08, 2009, 12:28 PM »
Best thing is to flush out all the crap/grease with GT85 or WD40.Heat up some grease in an old pan until it starts to liquify,then drop the freewheel in/pour over it-voila 1 clean/regreased freewheel...
