975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 01:46 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Another one of my dumb questions - re. brakes
Author Topic: Another one of my dumb questions - re. brakes  (Read 475 times)
Thejackal
« on: June 29, 2009, 10:19 PM »
Evenin all
A silly question, and no doubt one that has been asked and answered about a thousand times, but..................
How do you centre brakes, and keep them centred? I'm running a DC1020 on the rear, that I can manually centre, however, when the brake has been pulled only the RH arm (as you are sat on the bike) seems to move and then the LH arm/ block is left rubbing the rim?
Any answers? Any advice?
My thanks  :daumenhoch:
Offline oldtired
  • Dirty Old Man
Re: Another one of my dumb questions - re. brakes
« Reply #1 on: June 29, 2009, 11:08 PM »
problem is the spring is not centered , when you tighten up the shaft nut the whole thing is moveing, tighten it up full then release it a bit,1/4 turn , use a drift or something to tap the spring central then nip the shaft up again and check alighnment, if its right both arms will move the same amount,  :daumenhoch:  , you used to be able to get a tool to hold the springs central while tightning, dont know if you can still get em maybe LBS can help you out   ;)
