0 Members and 6 Guests are viewing this topic.
No reason why your setup should be bad dude, defo go with the brake bastard (london mod) as 2 is better than one eh When setting up a dual lower make sure the mobeus is sitting on top of the lower tabs by screwing out the cable adjusters until it sits flush to give you the maximum amount of travel in the gyro setup. Fit the top cable & dial in once all the lower half is provisionally set up. What brake/rim is he currently using Gary?
its excatly what i use
Get a pair of Stodgy's cheap clear pads, then give me a shout and we'll put it all together
