975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn December 01, 2024, 09:33 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Hollowbites
Author Topic: Hollowbites  (Read 802 times)
Voodoocars
Hollowbites
« on: June 13, 2009, 07:44 PM »
Hmmm... how do you get a pedal out of a primo hollowbite arm -left side- when the steel insert just turns >:(? I am aware the thread is reversed. New arm.....
Re: Hollowbites
« Reply #1 on: June 13, 2009, 08:55 PM »
ian
speak to fuzzynod, ask him to tap a grub screw in the end of the arm into the sleeve
subversion
Re: Hollowbites
« Reply #2 on: June 14, 2009, 08:21 AM »
Take the pedal out with the insert attached & then get it removed from the spindle. Put the insert back in with some loc-tite or similar
Re: Hollowbites
« Reply #3 on: June 14, 2009, 08:59 AM »
I've had this problem buddy... accordingly i've ripped the threads out that the insert screws into :'( :'( Im gonna have to take it to a local engineer :(, does anyone know how to re-build threads?
Voodoocars
Re: Hollowbites
« Reply #4 on: June 14, 2009, 11:11 AM »
If the alloy is knackered it can have a helicoil put in it. Do the inserts screw into the alloy then? Mine hasnt come out- its just turned a little in the arm. Got to ride today so i'll try and remove the pedal later.
Voodoocars
Re: Hollowbites
« Reply #5 on: June 14, 2009, 06:27 PM »
Sorted- combination brute force and a large mallet.
subversion
Re: Hollowbites
« Reply #6 on: June 14, 2009, 08:02 PM »
imo Hollowbites are great cranks! I've not had the issue with the pedal inserts (so far) & they are light (using a BSD Ti spindle, naturally) & certainly strong enough for me :daumenhoch:
Voodoocars
Re: Hollowbites
« Reply #7 on: June 15, 2009, 06:48 PM »
I must admit I do like the look of them and I have a ti spindle also so they are light. The only problem I've had is catching my jeans (I know- not girls jeans) on the clamp part of the arm. Its even chucked me headfirst down a ramp  :shocked: Been thinking about gettin' some mcneil conjoined.I got them off quad pete so if I change them he might duff me up   :-\.
jedi
Re: Hollowbites
« Reply #8 on: June 15, 2009, 08:10 PM »
i use hollowbites too.
mine turn in the arms a bit too but never an issue.
love em
