975768
TattooedYorkie
October 05, 2024, 12:58 PM
skyways
Topic: skyways (Read 910 times)
oldschoolfool
skyways
June 13, 2009, 11:04 AM »
hi there,could someone tell me if skyway mags are made in the US or the UK. i only want to know as i have a white set that says made in the uk.just curious really.
so whats the history.
also can Simplex mags have their hubs retightened.ive got a set with loose hubs but with the riveted hubs cant see how they adjust.
any one any help??
dave
oldschoolfool
Re: skyways
June 13, 2009, 11:08 AM »
ahhh!!,just read the post below about the uk skyways
any news on the simplex's would be a help though.
Superkav
Re: skyways
June 16, 2009, 12:00 PM »
One of the Burner guys on here should be able to help, try pm'ing Beard...or you could start a thread on the Burnerworld forum.
Simplex were a French made wheel and I don't think they offered the replacement bolt set like Skyway did. You could probably drill out the rivets and get some suitable bolts from B&Q to refit the hub. While you're at it you could give the hub plate a rub with some wet and dry to shine it up. That galvanised finish is just awful.
oldschoolfool
Re: skyways
June 18, 2009, 12:54 AM »
cheers dude,will do!
rockinlumberjack
Re: skyways
June 18, 2009, 11:09 PM »
I've restored my Simplex mags. The rear was like yours. I've replaced the rivets with bolts of the same diameter and tightened with nuts with Nylstop and they go well.
oldschoolfool
Re: skyways
June 20, 2009, 12:14 PM »
right stupid question time :LolLolLolLol:but what is nylstop!!??
rockinlumberjack
Re: skyways
June 20, 2009, 11:20 PM »
It's not a stupid question. Nylstop is a nut with nylon on the end of the threads who secures or locks the nut on the bolt.
justin
Re: skyways
June 21, 2009, 04:14 PM »
You will find all the info about SkyWay here oldschoolfool mate
Founded in 1963 in the USA..........
http://www.coloredtuffs.com/shop/index.php?act=viewDoc&docId=8
Last Edit: June 21, 2009, 04:16 PM by justin
oldschoolfool
Re: skyways
June 21, 2009, 10:16 PM »
nylstop....nylock...same thing,doh
. i thought it was some new fandangled thing.its just a nut wiyh a nylon end.haha
oldschoolfool
Re: skyways
June 21, 2009, 10:17 PM »
hey justin,cheers bud
skyways
