Is it worth gluing and clamping ?
Get a heat gun on it and see if will shape back - if it will flex back use some epoxy resin and clamp the bleeder!on plastic car bumpers I have used fibreglass bridger and had some great results with it... but heating it first is the key, plastic retains it's memory from the moulding process and under heat it will revert back to its original shape (u may have already known that, if so sorry to go on).got to be worth a try!
Quote from: sid1972 on May 24, 2009, 06:20 PMGet a heat gun on it and see if will shape back - if it will flex back use some epoxy resin and clamp the bleeder!on plastic car bumpers I have used fibreglass bridger and had some great results with it... but heating it first is the key, plastic retains it's memory from the moulding process and under heat it will revert back to its original shape (u may have already known that, if so sorry to go on).got to be worth a try! dont think it will work on skyways, because its not just plastic... ive tried it on zeds....the material just blisters under heat, besides, single skyways do come up on the bay, and you can usually get them for next to nawt, so its probably not worth wasting your time....
do what i do with mashed parts turn them into things that would make a good clock.i just made a mashed profile mini hub into a salt shacker pepper on the way next.
