975810
Robertflamn
November 28, 2024, 04:04 AM
rust
Topic: rust (Read 855 times)
gadd
rust
May 22, 2009, 12:06 AM »
ant one tryed this ?
http://www.frost.co.uk/item_Detail.asp?productID=9574&frostProductName=Restore+Rust+Remover+%28500ml%29+&catID=37&subCatID=&FrostCat=New%20Products&FrostSubcat=
bigsman
Re: rust
May 22, 2009, 09:58 AM »
Nope haven't seen it before but it looks similar to the effect you can get using oxalic acid and given that oxalic is cheaper and you can get from ebay that's what I'm trying next...have a google
dannywhiteley
Re: rust
May 22, 2009, 02:04 PM »
Try this:
These guts not being anything special I didnt give them the proper polish treatment, the way they look in the after pics are literally how I pulled them out of the vinegar with just a quick rinse and wipe dry.
As you can see, its worked. 24 hours in the Sarsons and the rust just fell off. It was all collected as little flakes in the bottom of the container, and anything that remained in the guts just wiped off clean.
Best bit is the vinegar only costs £1.40 for a big jar at Tesco.
Heres the before, during and after pics...
Swivel
Berm Worm
Ah feck it, go on then...
Re: rust
May 22, 2009, 02:05 PM »
Looks the nuts that dan
Deano
Re: rust
May 22, 2009, 03:00 PM »
That is a great piece of info in just 7pictures
Tesco's it is then
gadd
Re: rust
May 22, 2009, 10:06 PM »
Dad's gone to Tesco's
moanjam
Re: rust
May 22, 2009, 10:11 PM »
Quote from: gadd on May 22, 2009, 10:06 PM
i'd stick with the frost if its for your lass tho gareth
rust
