Fill with braze, then file down again back to the original contour.Not weld, the process is to unforgiving, unlike brazing which does not "pull" whilst cooling.Ad
Can you braze Ally then???Forgive my ignorance, I did a little metal work at skool but that was a while ago.
What temp do the ovens run at dan??
Quote from: Moschops on May 21, 2009, 10:57 PMCan you braze Ally then???Forgive my ignorance, I did a little metal work at skool but that was a while ago.Not sure, but I dont think the alloys will "mix" or "take"And there is an issue as to which has the highest melting point?Ad
Or maybe give this stuff a try... I haven't used it myself but the manufacturer claims it's suitable for powdercoating http://www.lab-metal.co.uk/?page=usesJohn
