975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 04:45 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Redline 401 Flight crank single pinch bolt
Author Topic: Redline 401 Flight crank single pinch bolt  (Read 887 times)
Offline BUBBS
« on: May 20, 2009, 10:37 AM »
I have got a Redline 401 single pinch bolt flight crank with a dimpled spindle but I need to get a bottom bracket for it does anyone know if I can get a bottom bracket which can be use with it
GREMLIN
Re: Redline 401 Flight crank single pinch bolt
« Reply #1 on: May 20, 2009, 10:42 AM »
A Mongoose 28tpi bottom bracket will do the job nicely  :daumenhoch:  G.
Offline DIRTBIKER250F
  • Home sweet home
« Reply #2 on: May 20, 2009, 11:03 AM »
Bubbs, check out Vert-ego for his Goose 28tpi bb's mate. Have used them on my Redlines and they are ace  :daumenhoch:
bigsman
« Reply #3 on: May 20, 2009, 12:49 PM »
Just a wee heads-up here - if you find the mongoose bb set via the 'flight cranks' section its £30 but if you go through bottom brackets its £40....no sure if it'll work for long but might be useful information  ;)
