975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 02:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Talk to me about pedal spindles.
Author Topic: Talk to me about pedal spindles.  (Read 2016 times)
Juju
« on: May 16, 2009, 08:33 PM »
Got the opportunity to buy some nos Diamond Back pedals.   Seeing as I have 3 Diamond Backs, with 1 more frame and fork on the way, this is a good thing.  However, the pedals I want are only available in 9/16 and I plan on using them with a 1pc which requires a 1/2 thread guage.
How easy is it to get pedal spindles. Are pedal spindles fairly standard, and can I change one for the other? Is it easy? do I also need different size bearings?
Look forward to hearing from you guys.
HEYWOOD BMX
Re: Talk to me about pedal spindles.
« Reply #1 on: May 16, 2009, 08:52 PM »
 :) Don`t know how easy it is to get spindles,but have swapped loads over to get 9/16 &1/2 sets.Wellgo make shedloads of pedals for almost every other company these days & these can cost from as little as£8 new,good for donor parts.Halfrauds & some bike shops also sell replacement pedal bearing sets for not much £.
Juju
« Reply #2 on: May 16, 2009, 09:25 PM »
I suppose that  I've been imagining the spindles themselves are different - logically thinking, its only going to be the "threads" on the spindles that vary....  not the whole spindle *doh*!
Well I was never very practical....
g_lamb
« Reply #3 on: May 16, 2009, 09:57 PM »
is 9/16 bigger than 1/2?  :-[ If so they could be tap and die'd????  ???
Offline sparky
« Reply #4 on: May 16, 2009, 10:15 PM »
Juju,
It depends on the pedals you want to change the spindles on, The DB MKS use standard MKS spindles and are different to the SR type pedal.
Juju
« Reply #5 on: May 17, 2009, 03:26 PM »
Yep - its a pair of DB- MKS bm10 style pedals.
Are spindles for this type readilly available?
« Reply #6 on: May 17, 2009, 03:52 PM »
I think you'd probably have to buy a set of standard MKS pedals swap your spindles over as required and then sell on the standard MKS pedals again with the swapped over spindles  ;)
