975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 06:03 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  redline twin pinch chainring n spider compatibility?
Author Topic: redline twin pinch chainring n spider compatibility?  (Read 667 times)
« on: May 15, 2009, 05:34 PM »
do sugino spiders fit twin pinch redlines ok?
cheers daz :daumenhoch:
Offline Gary72
Re: redline twin pinch chainring n spider compatibility?
« Reply #1 on: May 15, 2009, 10:51 PM »
I'm sure I used a Sugino spider with single pinch in the past.Think I had to grind down the top hat washer. Using a Tuff neck disc at the moment. But cant get to one of the bolts without moving the crank arm :tickedoff:
Just looked through my bucket account and it was a one piece crank when I used the spider on my Robby.
« Reply #2 on: May 16, 2009, 11:18 AM »
Ive always used a spider on my flites, shouldnt be a problem using a spider. You might have to grind the top hat washer a bit to fit snugly. :daumenhoch:
« Reply #3 on: May 16, 2009, 02:34 PM »
I think you are supposed to fit the top hat washer on the outside face of the spider rather than the inside so you don't have to grind it down.  It's on the Redline Flight crank fitting instructions I think...
« Reply #4 on: May 18, 2009, 08:53 AM »
coolio, cheers dudes, got a one piece chainwheel so sorted now :daumenhoch:
« Reply #5 on: May 18, 2009, 09:20 AM »
i have a Sugino fitted to my flights with no probs  :daumenhoch:
Offline Peter J
  • I have issues
« Reply #6 on: May 18, 2009, 10:13 AM »
Yep I've got em fitted no problem  :daumenhoch:
