975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 04:03 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Best thing to stick slack-fitting grips....?
Author Topic: Best thing to stick slack-fitting grips....?  (Read 713 times)
the_wheelie_king
« on: May 14, 2009, 02:21 PM »
Afternoon chums. I've got some Uni Hand-Grenades going onto a new build but they're quite a loose fit on the bars. My standard route would be to use sticky hairspray but it's not grippy enough. I know that if I use something like superglue I may make the grip rubber go brittle, so advice needed please...
Cheers, Bob  :)
Offline BrianP
Re: Best thing to stick slack-fitting grips....?
« Reply #1 on: May 14, 2009, 03:04 PM »
Hey Bob,
I use the rubber solution you get with puncture repair kits for fitting my grips.
Maybe this would work for you? How loose are the grips?
Brian  :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #2 on: May 14, 2009, 03:18 PM »
wrap the bars with self amalgamating insulation tape, its electrical tape that bonds to itself  over a couple of days to form single piece of tape when its set it has a sticky texture that grips the grips  :D  like glue, easy to get of when you need to as well.
bmxbert
« Reply #3 on: May 14, 2009, 03:24 PM »
hair spray or spray mount. work for me :daumenhoch:
Offline Glynnyboy
« Reply #4 on: May 14, 2009, 03:44 PM »
Went to the LBS the other week and asked the guy for whatever they use for grip fixing. He said nothing in particular and recommeded two things.
One was the rubber fixing glue in puncture repair kits.
The second which he recommended highly and said he been using it himself for the last 5 years, was clear laquer. The car kind as it is waterproof and not the hair kind.
 8)
the_wheelie_king
« Reply #5 on: May 15, 2009, 10:38 AM »
Thanks for the tips lads  :daumenhoch:
« Reply #6 on: May 15, 2009, 10:47 AM »
or buy new grips that fit properly  ;)
JT71
« Reply #7 on: May 15, 2009, 10:57 AM »
I'm guessing the usual subjects like laquer and wd40 aren't going to do it if the grips are slack, ie there's gap between bar and rubber.
you might have to put some tape around the bars before fitting grips.
teamsano
« Reply #8 on: May 15, 2009, 04:44 PM »
uni grips are fluted on the inside aren't they?
