975626 Posts in 138927 Topics by 6348 Members - Latest Member: Dannygee June 28, 2024, 06:23 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  gearing question
Author Topic: gearing question  (Read 1362 times)
Glen
gearing question
« on: May 13, 2009, 05:36 PM »
At the moment im running 9/27 if I drop to 26 how much rear wheel movement will I aquire?  My rear tyre is rubbing on my brake so i need to move it back.  Will that help or should I go 25/9?
Offline fugazi
Re: gearing question
« Reply #1 on: May 13, 2009, 07:14 PM »
Well 25/9 is nearer to the 44/16 "standard" & would allow the wheel to go back a bit, although have you looked at taking any extra spacers that may be in the brake blocks out on the inner brake arm side? This would mean adjusting the cable more thereby moving the brake arms away from the tyre. What tyre & brakes are you running?
« Reply #2 on: May 13, 2009, 07:29 PM »
is that horse poo on the brake ?
« Reply #3 on: May 13, 2009, 07:39 PM »
glen i reckon if ya had smaller inner washers on the brake blocks ya might get a smidge more clearance mate
even if ya have to file the buggers down
« Reply #4 on: May 13, 2009, 07:44 PM »
was just thinking if ya have less washers ya could adjust the brake to move the arms away from the tyre to get clearance
« Last Edit: May 13, 2009, 07:46 PM by Lazychubs »
Offline fugazi
« Reply #5 on: May 13, 2009, 07:45 PM »
 :daumenhoch: That's what I was getting at, pads nearer the brake arms means adjusting cable to bring pads back to where they were will move the arms from the tyre, like it clears when you pull the lever.
Bettyswallocks
« Reply #6 on: May 15, 2009, 04:56 PM »
Glen
I'm sure you've asked before about a 2.1 tyre on the rear of an LTF?
You're right a 2.1 tyre isnt much taller than a 1.95 but its fatter so you'll have clearance issues with the brake
I tried a KHE 2.1 tyre on the rear of both mine and my lads LTF's.... wouldnt clear the brake on either
Mine has 28/10 gearing, fly brake, regular chain
My lads 25/9 gearing, odyssey evolver brake, half link chain.... you'll more than likely need a half link if you go with 25/9 gearing
I tried smaller washers on the brake, it didnt work...  :(
The chainstays on an LTF are'nt wide enough apart at the brake mounts compared with other frames
Hope this helps...  :daumenhoch:
Offline fugazi
« Reply #7 on: May 15, 2009, 05:46 PM »
Cool you got it sorted, for now! A lot of frames seem to struggle to get anything over 1.95 in the back, but then again way back when anything over 1.75 used to give the same problems!
