975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 12:16 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Chewed up allen key?
Author Topic: Chewed up allen key?  (Read 2068 times)
mark 2
« on: May 07, 2009, 10:16 AM »
Don't know why I never thought of this before....grind the chewed bit down to some fresh meat. Voila. I thank you....... :-*
« Last Edit: May 07, 2009, 05:29 PM by mark j. »
teamsano
Re: Chewed up allan key?
« Reply #1 on: May 07, 2009, 04:56 PM »
strangely enough, i performed this 'mod' the other week too! lolZZ
lodge
« Reply #2 on: May 07, 2009, 05:23 PM »
Try this with a hacksaw and you will understand the meaning of hardened steel.  :2funny:
Offline Gary72
« Reply #3 on: May 07, 2009, 05:52 PM »
Try cutting down Odyssey pegs :buck2:
Re: Chewed up allen key?
« Reply #4 on: May 07, 2009, 07:08 PM »
Buy decent allen keys & you won't have to  :daumenhoch:
I use the Bondhus ones they are the best, they last forever  8)
buzzlightyear05
« Reply #5 on: May 07, 2009, 08:04 PM »
Ill secong that i use them at work, 3 years of using a 6mm Bondhus every day and its still perfect. They will also swap for a new one if you manage top mangle one FOC to.
dbone
« Reply #6 on: May 08, 2009, 04:26 PM »
This is how i extract chewed up allen heads,take a metal blade  put it in a hacksaw make sure its in the right way teeth facing the right way and cut a slit in the allen head then get a screwdriver and turn out as you would take out a screw ...job done.
« Reply #7 on: May 08, 2009, 05:50 PM »
Easier way is to hammer a torx head into the allen head and undo  :daumenhoch:
dbone
« Reply #9 on: May 08, 2009, 06:10 PM »
them are easy outs.......thats when one snaps the head off completely ....still good to have in ones toolbox.
dj_benice
« Reply #10 on: May 08, 2009, 06:13 PM »
bunch of men showing off their tools..... sounds like the late night shenanigans at MK   :shocked: :-* :shocked:
teamsano
« Reply #11 on: May 09, 2009, 08:42 PM »
i used a hacksaw, and it was no probs, maybe my blade was on the correct way? ;D
« Reply #12 on: May 10, 2009, 08:01 AM »
Maybe you were cutting cheap $hit allen keys  ;D
