975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 03:30 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Z-mag dyeing
Author Topic: Z-mag dyeing  (Read 1198 times)
gmac
Z-mag dyeing
« on: February 19, 2006, 03:21 PM »
I reckoned that they would never get used in the state they were in, so I got the old Dylon & salt mix out again, and brought these Z-mags back from the dead  :)
They were both in a sh!t state to start with. Both had heavy brake marks from using black blocks on white rims, and also the usual smearing of the decals   ::)
The one above is how they both were. I had already cleaned one, before I decided to go and get my camera
They came up pretty well with a bit of time spent with various cleaning agents, scourers, and wet & dry
Into the deadly dip for a transformation Kat Deeley would be proud of
Looking good after a couple of hours, but I left them in overnight anyway cos it was getting late.
The final result -
Guy
Re: Z-mag dyeing
« Reply #1 on: February 19, 2006, 03:25 PM »
look spot on i am doing some zs this week ran out of dylon at me shop
did you use 3 and 1/2 1b salt
gmac
Re: Z-mag dyeing
« Reply #2 on: February 19, 2006, 03:29 PM »
I didn't measure the salt, I just put loads in & I used 4 pots of Dylon. Maybe a bit excessive, but I just chucked in what I had  :daumenhoch:
« Last Edit: February 19, 2006, 03:32 PM by gmac »
Nana
Re: Z-mag dyeing
« Reply #3 on: February 19, 2006, 03:55 PM »
Will this work with z rims  :) i have a nos white and lilac could i make a matching set then ??? and what colour will make a match?
Offline ORB
Re: Z-mag dyeing
« Reply #4 on: February 19, 2006, 04:04 PM »
do em black Nana then you can be sure of a decent result
4 tins is best, and you may want to go as hot as you can keep it for the Z rims Tom, i had a bit of trouble getting them to take properly till i went nuts with the heat
oh, and on another point, i tried to dye some brake blocks, and it did not work.
12
Nana
Re: Z-mag dyeing
« Reply #5 on: February 19, 2006, 04:14 PM »
 ;D Brake blocks thats as bad as trying to dye mushroom grips ;D ok i will make a steel tank to put them on me hob ;) black you say :) is there no way of taking the lilac out as i have seen dye stripper stuff wonder if this would work  :-\ also made by dylon bye the way :)
Oh and thanks ever so mr orb
gmac
Re: Z-mag dyeing
« Reply #6 on: February 19, 2006, 04:19 PM »
Try bleachin the lilac one first. I reckon whatever colour you dye them, they will turn out different if they start different colours/shades.
Re: Z-mag dyeing
« Reply #7 on: February 19, 2006, 04:22 PM »
try to mix up kids paints to get lilac then dye white on then both different colour
cant think of an easy way bar black
