975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 12:28 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stem problem.
Author Topic: Stem problem.  (Read 771 times)
Stem problem.
« on: May 02, 2009, 07:37 PM »
Just snaped this! >:( wasnt even tightening it that hard! anyone got one lying about i could buy or have?, its an allen key type not bolt type, dad had an idea of glueing it with apoxy resin? good idea? :-\
HEYWOOD BMX
Re: Stem problem.
« Reply #1 on: May 02, 2009, 10:37 PM »
 :) PM me your addy.I`ll post 1 or 2 out to you on Monday.
Re: Stem problem.
« Reply #2 on: May 02, 2009, 10:42 PM »
Thank You Heywood :)
dodger
Re: Stem problem.
« Reply #3 on: May 03, 2009, 12:52 AM »
mate i might have 1 spare if i hav e il bring it with 2moro :daumenhoch:
chi11i
Re: Stem problem.
« Reply #4 on: May 03, 2009, 08:43 AM »
ive def got one in the garage if neither of the two above works out PM me and ill post it to you.
Re: Stem problem.
« Reply #5 on: May 03, 2009, 10:51 AM »
Magna - you didn't have your stem bolts tight when you did this did you?
Got to loosen them first, then tweak your headset with the top cap deal    ;)     It's not there to do owt except help you tighten your headset   :)
aditup 2234
Re: Stem problem.
« Reply #6 on: May 03, 2009, 12:37 PM »
This bolt should NEVER be "tight", "nipped up, yes, tight, no. Like Bob said, you have to loosen the pinch bolts first and this bolt is simply to take up play/preload on the bearings. Apart from that, it does not form any structural integrity of the headset as the pinch bolts are what holds it all together.
Ad  :daumenhoch:
