975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 07:21 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  when fitting an ad990 type brake...
Author Topic: when fitting an ad990 type brake...  (Read 868 times)
mattnice
« on: April 30, 2009, 10:52 PM »
on the front can you use a standard brake as i wanna set it up running thru the stem bolt/potts mod.
gonna go to triton to get one tomorrow.so i'd like to know what i need before
Matt
Re: when fitting an ad990 type brake...
« Reply #1 on: April 30, 2009, 11:02 PM »
A standard brake?  Do you mean any old AD990?  If so, then yes you can.  However, to make the best job of it you need to route the cable through it in the opposite direction, sooo....
Where the clamp is normally, you want to replace that with a pivoting barrel adjuster type thing, and you'll then need a knarp or other nipple clamp type thing to stick onto the end of the cable to hook into the other AD arm.
Failing that, you can go all midschool on it and simply ram the cable outer into the hook ended arm and clamp the inner ont t'other arm.  The cable doesn't route properly, but it will work   :)
If you can find a FS990 or a Hombre, they normally have everything in the box you need to do the front brake conversion.
mattnice
« Reply #2 on: April 30, 2009, 11:05 PM »
Cheers TBR
Thats everything answered
« Reply #3 on: April 30, 2009, 11:07 PM »
Sweet!
