975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 21, 2024, 08:49 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  anyone used 'Oxalic Acid' bath?
Author Topic: anyone used 'Oxalic Acid' bath?  (Read 1477 times)
Offline 20to26
« on: April 30, 2009, 07:10 PM »
...for removing rust from chromey bits?
The results over on bmxmuseum look impressive. Can we get this stuff here in the UK?
I've done the coke(zero)/foil thing which is great but sometimes doesn't get all the rust or black stain off.
Re: anyone used 'Oxalic Acid' bath?
« Reply #1 on: May 01, 2009, 12:41 AM »
Used it loads of times, it really is as good as they say.
On ebay type....... Oxalic Acid
Disolve said OA in water, immerse rusted part for 24 hours and they wash off.  All the rust has gone.
Offline 20to26
« Reply #2 on: May 01, 2009, 09:07 AM »
Thanks Sean, does OA effect aluminium or anodizing at all?
Juju
« Reply #3 on: May 01, 2009, 05:16 PM »
Oxalic acid works by attracting the positively charged ions in the iron oxide (rust).
I dont think its going to harm aluminium, as aliminium oxide is a different chemical compound.
Its safe, but apparently its not great for the environment to pour your bath straight down the plug hole when finished - I've seen suggestions that you should at least neutralise the acid by adding an alkali to make the bath at least ph neutral.
A small qualtity of caustic soda might do it.
« Reply #4 on: May 01, 2009, 06:28 PM »
Doesn't harm aluminium or decals at all, only the rust is affected.
rhino_mac
« Reply #5 on: May 01, 2009, 06:37 PM »
Don't for Gawds sake add Caustic to Oxalic. It will boil vigourously instantly and "explode" (it doesn't explode as such but the reaction is so vigourous it looks like it).
And always dilute Caustic Soda by adding Caustic to water, not the other way round or you get the same effect!
rhino_mac
« Reply #6 on: May 01, 2009, 06:41 PM »
Sorry, meant to add to neutralise an acid such as Oxalic, dilute the comncentrated solution you've used to treat the frame, then add as much water as you possibly can to make it as dilute as possible.
Then add "Soda Ash" (Sodium Carbonate or Soda Crystals) to the bath. Best to dilute these in water first too.
Basically, always use as much of the dilute chemicals to each other, as slowly as possible. Acid + Alkali = mucho heat if they are concentrated
« Reply #7 on: May 02, 2009, 12:43 AM »
I've tried OXY 10 in a bird bath
Got rid of my budgie's acne a treat !  :4_17_5:
Offline 20to26
« Reply #8 on: May 02, 2009, 03:59 PM »
LOL...
ok, so I should be able to put complete wheels into an OA bath to clean up the spokes & axles without any effect to the hubs & rims?
I presume the grease (or what's left of it) will also dissolve.
Then I can toss the diluted OA water onto all the weeds in my garden...
Juju
« Reply #9 on: May 02, 2009, 06:48 PM »
Quote
I've heard some of your birds could do with a good bath...........
