975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 12:33 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Beartraps
Author Topic: Beartraps  (Read 863 times)
Thejackal
Beartraps
« on: April 28, 2009, 02:12 PM »
I have recently won a pair on flea-bay.
They don't seem to run quite as smoothly as I thought they would. How easy it is to take them apart and re-grease them etc? Is ther a (repro) kit available?
Similarly, with the cages will they buff up? Can I get some more NOS ones?
In total fairness to the seller, they hadn't been described as perfect or NOS or anything like that.
Thanks  :daumenhoch:
Re: Beartraps
« Reply #1 on: April 28, 2009, 07:08 PM »
are they hutch beartraps?  mine are velvet smooth....     but thet are nos i suppose....    :daumenhoch:
Re: Beartraps
« Reply #2 on: April 29, 2009, 06:05 AM »
If they are Suntour beartraps then they are as easy as a normal pedal to strip and re-grease.  Pics would be a good starting point  ;).
Thejackal
Re: Beartraps
« Reply #3 on: April 29, 2009, 07:23 AM »
They are Hutch bear traps. They feel/ sound a bit gritty when turned.
If I knew how to upload pic's, I would................  ;)
Offline pkradman
Re: Beartraps
« Reply #4 on: April 29, 2009, 10:01 AM »
somthing dont sound right as the barings are a sealed cartridge .. u can get replacments im sure ... just undo the allen bolt on the end and follow ya nose  :daumenhoch:
Offline pkradman
Re: Beartraps
« Reply #5 on: April 29, 2009, 10:03 AM »
   .. :LolLolLolLol: well done sam that commnet was a great help to carl ... :uglystupid2:
Thejackal
Re: Beartraps
« Reply #6 on: April 29, 2009, 01:16 PM »
Thanks Lee.  :daumenhoch:
Re: Beartraps
« Reply #7 on: April 29, 2009, 08:04 PM »
 :knuppel2: :knuppel2:
« Last Edit: April 29, 2009, 08:06 PM by meticus »
dan-dare
Re: Beartraps
« Reply #8 on: April 30, 2009, 12:53 PM »
Take the body off the spindle.
Remove dust cover on the bearings.
Clean out with WD40.
Pack with good bearing grease.
Replace dust covers.
Re-assemble onto spindle.
Should be loads better. :daumenhoch:
Thejackal
Re: Beartraps
« Reply #9 on: April 30, 2009, 12:57 PM »
Thanks Dan Dare. I will give it a go over the weekend, unless the sun is shining, then it's beer garden all the way.  :Great_Britain: :4_17_5:
