975768
TattooedYorkie
October 05, 2024, 10:50 PM
Filing Axles
Topic: Filing Axles (Read 471 times)
Swivel
Berm Worm
Ah feck it, go on then...
Filing Axles
April 27, 2009, 04:25 PM »
Guys, my rear dropouts on my TRM are very narrow, so I need to file down the axle. What advice can you give to prevent me from fooking it up? Never done it before and i'm a bit nervous as I need these wheels for the 3rd of May ride.
Thanks in advance,
Matt
dan-dare
Re: Filing Axles
April 27, 2009, 04:27 PM »
Use a grinder.
harris
Founding Fathers
Hoffman's Love Child
Re: Filing Axles
April 27, 2009, 04:28 PM »
i used a square file around 6mm wide i put a nut on as wide as the file and filed between that way i wouldnt slip and damage the other threads
even put 2 nuts on to lock it.
HUTCHMAN
540 Air
Re: Filing Axles
April 27, 2009, 06:29 PM »
if you haven't got a square file you could always use a flat file and use the non "safe edge".
Gary72
Site Supporter
BMX Nerd
Re: Filing Axles
April 27, 2009, 06:34 PM »
Are they sealed bearing hubs or loose ball, might have an axle lying around you can have?
Filing Axles
