975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 12:37 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Advice on Mongoose rear brake...
Author Topic: Advice on Mongoose rear brake...  (Read 511 times)
hhp802n
« on: April 16, 2009, 05:05 PM »
Hi all...
I usually run with Coaster brakes on my old geese, but have decided to finally break my mold and fit a rear brake to my 1980 frame...
I have purchased a non era specific Dia compe 901 set which has a much longer fitment than required, i fear if i fit it then it will foul the frame, or will need so many penny washers it will look ridiculous?
am i being stupid here?  should i have purchased a different setup, can i just change the guts of the brake onto a shorter bar so that it fits?
Advice please guys...
Matt
« Last Edit: April 16, 2009, 05:27 PM by hhp802n »
hhp802n
Re: Advice on Mongoose rear brake...
« Reply #1 on: April 16, 2009, 05:26 PM »
OK after running through the pics in the museum i have realised my mistake...  (stupidity)
I need a grommit to push the brake out further from the frame...
Can i use anything else other than a specific brake part?  Just wondering where i might get just the grommit???  Any one got one going spare?
Matt
« Reply #2 on: April 16, 2009, 05:37 PM »
You can use the cooling fins from a Skyway Pro Pad< I have some somewhere, but since I moved house a month ago, I'm not sure where they are  :(
daz bmx it!
« Reply #3 on: April 16, 2009, 05:38 PM »
Are these not even rarer than the said grommit!  ??? :D
« Reply #4 on: April 16, 2009, 05:44 PM »
Are they  ???
I'v got $hit loads  :)
Somewhere  :-[
Offline sawzall
« Reply #5 on: April 16, 2009, 05:53 PM »
I USUALLY USE THE WASHERS WHICH ARE USED WHEN THE BRAKE BRIDGE IS ROUND , JUST PUT THEM TOGETHER TO FORM A THICK WASHER-SPACER,IF YOU WANT SOME PM ME YOUR ADDRESS AND I WILL SORT YOU SOME OUT ;)
