975798 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 16, 2024, 01:44 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  How much weight does chrome add to a frame.
Author Topic: How much weight does chrome add to a frame.  (Read 5241 times)
lodge
« on: April 16, 2009, 11:37 AM »
I keep reading that chrome adds around 1lb in weight to a frame anyone know if this is true, just curious.
Re: How much weight does chrome add to a frame.
« Reply #1 on: April 16, 2009, 11:44 AM »
buy a nos old school hutch f/f, weigh it, build it up, ride it, un build it, re-weigh it, minus the 2nd weight from the first and you have your answer  :daumenhoch:
« Reply #2 on: April 16, 2009, 12:47 PM »
I don't know the answer, but I find it hard to beleive, it would add 1lb in weight   ???
moley
« Reply #3 on: April 16, 2009, 12:52 PM »
When you take off some peeling chrome it doesn't weigh much!!
Its only plated and is very thin!!
On an OS F+F weighing around 6 lbs.   1lb is way too heavy.
And Daz!!  Stop smoking the hard stuff.  Your whacked out of your skull!!  :LolLolLolLol:
JT71
« Reply #4 on: April 16, 2009, 01:42 PM »
obviously there is a weight, but never a pound.
I know that mercedes racing cars were traditionally silver as they found they saved a couple of pounds over the weight of the car, but that's paint, probably primer and top coat over a whole car, so they stripped then paint and from then on didn't paint the car's body work.
I'm sure that thin chrome plating wieghs less than paint, but I could be wrong.
« Reply #5 on: April 16, 2009, 01:45 PM »
S&Ms zinc coating weighs less than paint and chrome, cos its like a colouring, rather than a coating.
Dont know if that helps any ......  :-\   :LolLolLolLol:
moley
« Reply #6 on: April 16, 2009, 01:52 PM »
I think we need someone who wants to rechrome their F+F.
They can peel off all the old Chrome and weigh it!!
Who's up for it!!  :LolLolLolLol:
« Reply #7 on: April 16, 2009, 01:57 PM »
Or, they could just weigh it before, and after its been rechromed ?  ???  :LolLolLolLol:
moley
« Reply #8 on: April 16, 2009, 02:03 PM »
Cheers Alex!!  :(
I was hoping for somebody to be suckered in and spend all day peeling chrome of their F+F!!  ;D
JT71
« Reply #9 on: April 16, 2009, 02:09 PM »
F***
HOW WILL I GET THIS CHROME BACK ON?
lodge
« Reply #10 on: April 16, 2009, 02:20 PM »
In the latest issue of Ride: Hanson Little's Bike Check which is a chrome Mutiny Mystic, He is asked how much weight the chrome adds, he replies "the chrome added 1lb in weight to the frame alone"
I know its hard to believe but its not the first time I have heard this. I have also heard powdercoat adds a substantial amount of weight to a frame?
Anyhow its not important I was just curious.
bof
« Reply #11 on: April 16, 2009, 02:27 PM »
Proclass35 stripped the paint off his sons bike and saved 3oz.  :shocked:
« Reply #12 on: April 16, 2009, 02:44 PM »
That has to be a piss take, dont it?
I remember in the 80s there were bike tests that listed 2 frame weights, one chrome, one paint. In the 90s that seems like such a joke but here it is again. Look out for goggles on open face helmets next!
« Reply #13 on: April 16, 2009, 07:17 PM »
im on me holidays    :D
fuzzywig
« Reply #14 on: April 16, 2009, 07:21 PM »
Chrome adds quite a bit...  Compare chrome rim weights to anodised ones
fuzzywig
« Reply #15 on: April 16, 2009, 07:24 PM »
22g on a Odyssey Midway rim
« Reply #16 on: April 16, 2009, 11:13 PM »
True, my chrome rim ways a ton! :LolLolLolLol:
fuzzywig
« Reply #17 on: April 17, 2009, 12:05 AM »
 ;)  22g  is a massive amount....  way more than you'd save by using hollow stem bolts ::)
Bettyswallocks
« Reply #18 on: April 17, 2009, 12:15 AM »
I had a Chrome grim reaper frame and i weighed it before building it up... 4lbs
According to easterns website the painted ones weigh in at 4lbs no mention of the chrome ones being heavier... mine wasnt...  :daumenhoch:
Maybe chrome finish does make a frame heavier..... by a few milligrams...   :-\
moley
« Reply #19 on: April 17, 2009, 12:33 AM »
Any Cro-Mo F+F already has Chromium in it!!
So lets say the tubing is 1mm thick, which it isn't.  The Chrome plating is nowhere near 0.1mm thick.
So lets say a F+F weighs 6 lbs and the chrome plating is 0.1mm thick.   Then that would make Chrome plating weigh 0.6lbs (which still isn't 1lb).
But only if the Chrome plating is 0.1mm thick, which it isn't.  Its much thinner!!
And the F+F isnt 1mm thick either, its much thicker!!
Do the math!!
All of the Chromium in a F+F will probably weigh more than the Chrome plating because its distributed throughout the Frame and forks.  The Chrome plating would only be microns thick!!  :D
So it can't weigh 1lb?
Thats what I think!!  ???
reay900tap
« Reply #20 on: April 17, 2009, 08:59 AM »
I had my daily flybikes mosca chromed..
The frame straight out of he box weighed 5.3lbs (19.8tt length) it was powdercoated pink :-*.
once back from the chromer it was a dead 5lbs! and that was triple plate chrome also..
hope this helps
Offline jT Racing
  • i like bikes. :/
« Reply #21 on: April 17, 2009, 12:59 PM »
1lb lol. it weighs fook all, a few grams tops. the plating is microns thick not mm's. if some tool at the plating company lets your tubes fill up with copper doing a high fill plate then you may get a weight from that, but that's just a tardy workman. grams mate, grams. not nigh on 1/2 kilo LOL.
ding dong
moley
« Reply #22 on: April 17, 2009, 02:31 PM »
Werd!!  :daumenhoch:
Broggie
« Reply #23 on: April 17, 2009, 07:26 PM »
Oh gawd, does it matter...just have a shit before you ride the bike and you'll go faster  :LolLolLolLol:  ;)
Ray.
« Reply #24 on: April 17, 2009, 08:43 PM »
Ray.
ure so new skool ray lol
