975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 09:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  too close?
Author Topic: too close?  (Read 862 times)
Offline Peanut
too close?
« on: February 16, 2006, 01:08 PM »
I tried something last night and think I may have found my brake problem. I've been running the pads very close to the rims, theory being that the closer they are the more pressure I can impose with the levers. Tried slackening them off a bit last night and they now bite the rim.
Is there an optimal distance for brake pads??
Or am I just a tw@t?
Sanmarcopizza
Re: too close?
« Reply #1 on: February 16, 2006, 01:11 PM »
There is a chance that your little digits are not applying their maximum pressure at full stretch, so now that the lever travels closer to the bar them pinkies can pull harder.
Re: too close?
« Reply #2 on: February 16, 2006, 01:25 PM »
its trial and error.
you do need a little gap, to get more feel to the brake
Re: too close?
« Reply #3 on: February 16, 2006, 07:03 PM »
Yeah, I'd agree with them two  ^^^^^^^  :)
A clear air gap is needed for sure. What you could do is set that gap and then give your levers a bend if you want more space between your bars and levers.  If you see what I mean...  :)
Nana
Re: too close?
« Reply #4 on: February 16, 2006, 07:48 PM »
Are you using oddys as i found this that the bigger the gap the better the feel and more bite weird huh :-\ also found if you tilt your pads so every part of the rim gets hit they work better ???
