975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 07:22 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tensioners
Author Topic: tensioners  (Read 835 times)
telelogic
tensioners
« on: April 13, 2009, 03:34 PM »
Anyone know of a 10mm chain tensioner that will work with pegs?
I'll be using a 10mm to 14mm shim to bring my axle up to the size of my dropouts, so need something flat.
JT71
Re: tensioners
« Reply #1 on: April 13, 2009, 03:39 PM »
colony do a peg, alloy, with a tensioner built in,  not sure if they do them 10mm though.
telelogic
Re: tensioners
« Reply #2 on: April 13, 2009, 03:46 PM »
they won't fit :(
the axles on my tuffs are too short.
plus the fact that part of that peg sits in the dropout which will be full of my shim.
HEYWOOD BMX
Re: tensioners
« Reply #3 on: April 13, 2009, 04:35 PM »
  Someone used to make a tensioner with built in-10to 14mm spacer.Think it was ID, Billys might still have some in stock.
« Last Edit: April 13, 2009, 04:53 PM by HEYWOOD BMX »
rarman1
Re: tensioners
« Reply #4 on: April 13, 2009, 04:55 PM »
take the flange of the axle convertor to make a shim that sits inside the dropout,
then use a 10mm tensioner and 10mm peg :daumenhoch:
Re: tensioners
« Reply #5 on: April 13, 2009, 06:34 PM »
stupple ran pegs on his t1 when he went new skool
no tensioners tho but pegs kept coming off as axles wasnt long enuf
so be carefull
JT71
Re: tensioners
« Reply #6 on: April 13, 2009, 06:44 PM »
let me have a looky in my garage, i reckon i might have a pair of tensioners with a 10mm hole and slot to make them fit a 14mm dropout, but i might be wrong.
JT71
Re: tensioners
« Reply #7 on: April 13, 2009, 08:26 PM »
okay, I have in my possesion a pair of tensioners, 10mm hole but a built in 10mm to 14mm adapter.
however the washer part is very thick, and the thread is very long, but that could be shortened.
any use to you?
Bettyswallocks
Re: tensioners
« Reply #8 on: April 13, 2009, 11:03 PM »
I'd be wary of running a 10 to 14mm shim and pegs you'll deffo bend the axles...  :(
telelogic
Re: tensioners
« Reply #9 on: April 14, 2009, 12:35 PM »
any use to you?
I'd love to give those a go :daumenhoch:
send me a pm letting me know what I owe ya'
rarman1
Re: tensioners
« Reply #10 on: April 14, 2009, 10:56 PM »
or try 10 - 14mm axle convertors (the ones that screw on) they work perfect on my nankai hub :daumenhoch:
Re: tensioners
« Reply #11 on: April 15, 2009, 08:01 AM »
or get proper wheels and dump the Tuffs?   ???
