975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 21, 2024, 12:47 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  re-threading 1" threaded forks?
Author Topic: re-threading 1" threaded forks?  (Read 1225 times)
Offline ruff n tuff
« on: April 12, 2009, 10:03 PM »
Does anyone know if there is a way to re-thread worn threads on a 1" threaded fork - bought some from here that are shagged and need a miracle - I like them (Silverfox) but they are unuseable as they are...
Some thoughts:  smother in metal epoxy stuff and re-thread, weld over the top and re-thread?
Any ideas / experience?
buzzlightyear05
Re: re-threading 1" threaded forks?
« Reply #1 on: April 12, 2009, 11:05 PM »
You can get the right size die for them but i cant remember were for the life of me. They definatley need building back up before re-threading.welding may distort the thin tube so epoxy may be the way to go. If there for a carpet queen maybe try using ptfe tape or electrical tape,it may well allow it to nip up enough :daumenhoch:
Offline ruff n tuff
« Reply #2 on: April 12, 2009, 11:10 PM »
I have some metal epoxy used ro repair engine blocks etc so should be strong enough - I'll take it into work to see if the guys in the workshop can do anything.
Not going to be a carpet Queen!  just a rough rider...
Does anyone know what thread it is?
« Reply #3 on: April 12, 2009, 11:11 PM »
argos cycles Bristol  :daumenhoch:
I had a pair of Curtis forks that were knackered - they sorted them for me  :daumenhoch:
buzzlightyear05
« Reply #4 on: April 12, 2009, 11:25 PM »
I think they are 1' BSC which is 26tpi i belive.
Offline ruff n tuff
« Reply #5 on: April 13, 2009, 07:21 AM »
Did they charge much?  The forks aren't worth a lot but I like the look of them and would rather keep them!
Offline ruff n tuff
« Reply #6 on: April 13, 2009, 07:22 AM »
Thanks for the info  :daumenhoch:
fouronethreeoh!
« Reply #7 on: April 13, 2009, 07:08 PM »
« Reply #8 on: April 13, 2009, 07:11 PM »
About a fiver !
Offline ruff n tuff
« Reply #9 on: April 13, 2009, 08:54 PM »
Have a looky here.
http://www.radbmx.co.uk/forum/index.php'topic=82808.0
The first thing I did was a search on 1" threads - how rubbish am I at searching?  Thanks for the link - I am leaning towards sending my forks to Argos cycles -I'll give them a ring tommorrow.  :)
