975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 01:59 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cleaing Gyro Bearings
Author Topic: Cleaing Gyro Bearings  (Read 647 times)
Offline wildon
« on: April 09, 2009, 08:54 AM »
Ok, i got a couple of first gen Odyssey Gyros i was going to clean up, re-finish and use on my builds instead of a couple of Gyro 2's i got.  Problem i got is the bearings in the movable parts in the middle have dirt inside and they do not run too smooth anymore.  Can't take them apart so is there something i could do ... maybe put them in something to eat away at all the grease and dirt etc?
Cheers  :daumenhoch:
Offline Bigfrawg
Re: Cleaing Gyro Bearings
« Reply #1 on: April 09, 2009, 08:56 AM »
soak in wd40  :daumenhoch:
snav69
« Reply #2 on: April 09, 2009, 08:57 AM »
Soak them inWD40 or De-Greaser but the problem with those 2 processes is that they will remove the grease from the bearings and i'm not sure if you can regrease them as i haven't seen them ::)
 :coolsmiley:
snav69
« Reply #3 on: April 09, 2009, 08:58 AM »
I type tooooo slow  :LolLolLolLol:
Offline wildon
« Reply #4 on: April 09, 2009, 09:39 AM »
OK cheers i'll try that ... but yeah i think re-greasing them may be a problem ...  :daumenhoch:
HEYWOOD BMX
« Reply #5 on: April 09, 2009, 11:16 AM »
 :) Heat a wad of grease in a pan until it turns to liquid (be careful-you`re not frying chips!) drop in the gyros,remove carefully with tongs or similar. Allow the parts to cool and then give `em a good clean-jobs a good`un.
Offline wildon
« Reply #6 on: April 09, 2009, 11:46 AM »
Brilliant idea! Cheers  :daumenhoch:
