975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 02:46 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fitting a Takagi 3 Piece crank.
Author Topic: Fitting a Takagi 3 Piece crank.  (Read 569 times)
ROX
« on: April 08, 2009, 09:39 AM »
I fitted my Takagi 3 piece crank with no instructions and it was fine, however, I removed one of the crank arms to fit a bottom bracket boot (ready for racing), and since putting the arm back on it makes a horrible sort of squeaky, scraping noise!
No parts are where they shouldn't be as I basically took it off and put it back on.
Any ideas why it's making the noise and how I can get rid of it?
Cheers!
ROX
Re: Fitting a Takagi 3 Piece crank.
« Reply #1 on: April 13, 2009, 06:49 PM »
OK it's because the locking bolt keeps working loose, it didn't come with a spring washer or serated washer.
Should it have?
Shall I loctite the bugger in for racing on Sunday?
« Reply #2 on: April 14, 2009, 02:41 AM »
Should it have?
A dab of Loctite and plenty of torque on the bolt  :daumenhoch:
ROX
« Reply #3 on: April 14, 2009, 10:43 AM »
« Reply #4 on: April 14, 2009, 12:37 PM »
Forgot to mention to grease the axle flats too, this will reduce further risk of creaking  ;)
