975884 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 04:43 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spoke cleaning
Author Topic: spoke cleaning  (Read 919 times)
spoke cleaning
« on: February 12, 2006, 12:05 PM »
what is the best way to clean up spokes as i dont want to do them more harm than good,i normally bin them and replace for new as i have so many rims and spokes i thought what the hell restore the better ones.thanks dan
Re: spoke cleaning
« Reply #1 on: February 12, 2006, 12:49 PM »
soapy water and wirewool
if you want to go to town use autosol
best to strip the wheel to do it
i usually get part way through cleaning spokes then just buy a new set
greentoad
Re: spoke cleaning
« Reply #2 on: February 12, 2006, 01:03 PM »
Hi
For a quick result and if the wheel is built up, use the acid solution (like you use on alloys etc), then use a worn household sponge / scourer and finally blast with a jetwash / hose.
You can then put some polish on a rag, put the rag through the spokes and pull / push the rag and give them a quick polish that way.
This is pretty much how you clean motorcycles.
NB - meths is good added to water to clean items aswell.
Hope this helps.
J
