975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:08 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  nitromors
Author Topic: nitromors  (Read 1068 times)
Offline 20to26
nitromors
« on: March 20, 2009, 07:55 PM »
will this stuff remove red paint that has been splashed on a black Bulldog caliper without damaging the original black?
If not any ideas what will?
Thanks
Re: nitromors
« Reply #1 on: March 20, 2009, 08:22 PM »
gently use thinners first, as nitromores is very aggresive and could damage the original finish....
steve Beech TA
Re: nitromors
« Reply #2 on: March 20, 2009, 08:50 PM »
Sorry mate i cant think of anything that will do the job, if it takes the red of it will take the black of  or effect the finish :-\
steve Beech TA
Re: nitromors
« Reply #3 on: March 20, 2009, 08:51 PM »
What about stripping the lot take to bits and re spray it aint that hard and may be easier in the long run  :daumenhoch:
Offline 20to26
Re: nitromors or oven pride?
« Reply #4 on: March 21, 2009, 12:23 PM »
thanks guys, I'll try thinners first and then the respray route.
Will Nitromors remove paint & rust off an old steel chainring that needs a respray? Or should I try Oven Pride for that?
Re: nitromors
« Reply #5 on: March 21, 2009, 05:07 PM »
chainring will most probably be anodice, so oven pride on that normally....  but if there is rust on it, it will be a steel chainring so nitromores on that...
Offline Stodgy
    • RADBMX Shop
Re: nitromors
« Reply #6 on: March 21, 2009, 05:10 PM »
I think Bulldogs are powder coated so you'll probably be okay. Don't hold me to it though!!
Try a little spot of the 'mors on the back of the brake and leave it for 10mins to see if it starts to lift.
