975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 08:58 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pro Neck Stem complete resto finished check out results
Author Topic: Pro Neck Stem complete resto finished check out results  (Read 1414 times)
Looking 2 get some weld in this dent 2 get it built up so can re-shape and finish. Can't do it myself cos ain't got access 2 the equipment.
« Last Edit: May 12, 2009, 10:21 PM by ANIMAL »
Found somebody 2 do it 4 me, even tho can Tig weld myself no access 2 equipment. Excellent job 4 a £5  ;)
Only needs some fettling and a good polish then off 2 the annodisers . Then can fit the quill I made from stainless 4 it  ;D May even get the bolts chromed when I source some . Heres the quill  8)
lets see the after pics.
No worries when I get that far got so much resto on the go not sure where 2 start  :LolLolLolLol:
Here we go  8) Got new bolts drilled out centre on the big one 4 wedge bolt, then off 2 the chromers  ;) Next filed up repair then wet and dry down through the grades and numb fingers  :LolLolLolLol: . A buff and a polish later bling bling. Then fitted the new stainless quill and new chrome bolts + stainless cap screws  :daumenhoch: Heres the result so chuffed with this cos it was scrap when I got it  :smitten:
Offline Steve P
Re: Pro Neck Stem complete resto finished check out results
« Reply #5 on: May 12, 2009, 10:22 PM »
Nice work mate ... I've done a few of these myself and it's defo restoration therapy  :daumenhoch:
Offline Gary72
« Reply #6 on: May 12, 2009, 10:23 PM »
Job well done :daumenhoch:
How does the quill fit to the head. Is it just a interference fit and pressed in?
Gary
« Reply #7 on: May 12, 2009, 10:23 PM »
nice   8)
Offline GTnumber1
« Reply #8 on: May 12, 2009, 10:25 PM »
dude thats turned out well sweet  :smitten:
were did you get the stem cap bolts from?????????????????????????????
Offline double chevron
« Reply #9 on: May 12, 2009, 10:26 PM »
can't beat a good stem resurrection !
Really nice, you should have taken pics with a bit more light, would have been blinding   :daumenhoch: :daumenhoch:
Offline brass monkey!
« Reply #10 on: May 12, 2009, 10:28 PM »
 :4_17_5:
« Reply #11 on: May 12, 2009, 10:38 PM »
Showmanship! :4_17_5:
« Reply #12 on: May 12, 2009, 11:00 PM »
Yep all the quills are interferance fitted and held tight with the big bolt  ;) The cap screws are exact replacements length etc that I sourced from my buddy in his engineers supply shop  :daumenhoch: thanks 4 all the kind words fellas much appreciated, makes all the hard work even more worth while. It looks even better outside in the sun blinding infact  ;D
« Reply #13 on: May 13, 2009, 07:57 AM »
But that thread woudn't be complete without a pic of your hands after the polishing job !  :LolLolLolLol:
Offline WARDY
« Reply #14 on: May 13, 2009, 08:05 AM »
seen this in the flesh on Saturday just gone , fooking blinging , excellent work Steve  :daumenhoch:
